Tire and wheel shop
DREDnot
578
Phoenix, AZ
Its actually easy to do yourself. Deflate, un-bolt, lift off upper plate, remove old o-ring or valve stem, clean mounting surfaces, lay new o-ring in groove, lay top plate back in place, carefully torque to spec as not to dislodge o-ring. re-inflate.
Its made to be able to be done in the field with hand tools.
Thunderbirds
493
Northern Black Hills South Dakota
I've learned from others on this forum and had great success with just a tiny amount of Slime on the seal, just as a precaution. It fills in any unevenness or scratches if present.
And I second DREDnot's opinion in his post. As long as you don't have to mess with the run flats, pretty simple. Follow torque specs!
Coug
4,732
Olympia/WA
Disassembly they can stick, so having some liquid tire lube (or some dish soap thinned down) around the edge of the rim to get into the gap as you pry will keep it from resticking itself as you go around
KKroger
150
KC MO
by the guys with this truck...
KKroger
150
KC MO
Remove Valve Core, Remove NUTS, at this point you can support the wheel face on a bucket if you want or something then use a prybar to get the wheel face off the assembly. recover your O-Ring and don't STRETCH it, Unlikely to find a vendor in Town with the O-Ring or O-ring Stock... Runflat is another thing, you can just pull it out with brute force if you don't plan to re-use the tire... or squeeze it down with a ratchet strap till nearly touching in the middle and fight it out with a couple prybars, then put it in the new tire if you wish... or use the PVC Beadlocks offered by Trailworthy Fab... then place the assembly on the wheel and align that o-ring a good bit of slime will do. then bolt it back together.
Coug
4,732
Olympia/WA
And again, tire lube will make removing and installing the rubber runflat soooo much easier than trying to do it dry.
I used grease instead of tire slime, in order to hold the o-ring in place while doing assembly. I would assume it would also help the o-ring slide into it's groove if it becomes slightly misaligned during reassembly. I have seen dry o-rings that came a little out of the groove become smashed and distorted, too much friction to return into the groove when unlubed.
One other trick I've heard a few times is if the o-ring stretched a little, sometimes putting it in the freezer will help tighten it back up.
