Humm
- 2
- 3
- Senoia, GA
Anyone know of a shop in Atlanta area that can break down a Hmmwv wheel? I need a new seal installed. Thx for any info.
.Its actually easy to do yourself. Deflate, un-bolt, lift off upper plate, remove old o-ring or valve stem, clean mounting surfaces, lay new o-ring in groove, lay top plate back in place, carefully torque to spec as not to dislodge o-ring. re-inflate.
Its made to be able to be done in the field with hand tools.
by the guys with this truck...Its actually easy to do yourself. Deflate, un-bolt, lift off upper plate, remove old o-ring or valve stem, clean mounting surfaces, lay new o-ring in groove, lay top plate back in place, carefully torque to spec as not to dislodge o-ring. re-inflate.
And again, tire lube will make removing and installing the rubber runflat soooo much easier than trying to do it dry.Remove Valve Core, Remove NUTS, at this point you can support the wheel face on a bucket if you want or something then use a prybar to get the wheel face off the assembly. recover your O-Ring and don't STRETCH it, Unlikely to find a vendor in Town with the O-Ring or O-ring Stock... Runflat is another thing, you can just pull it out with brute force if you don't plan to re-use the tire... or squeeze it down with a ratchet strap till nearly touching in the middle and fight it out with a couple prybars, then put it in the new tire if you wish... or use the PVC Beadlocks offered by Trailworthy Fab... then place the assembly on the wheel and align that o-ring a good bit of slime will do. then bolt it back together.
Got it done . Thanks for the good info !And again, tire lube will make removing and installing the rubber runflat soooo much easier than trying to do it dry.
I used grease instead of tire slime, in order to hold the o-ring in place while doing assembly. I would assume it would also help the o-ring slide into it's groove if it becomes slightly misaligned during reassembly. I have seen dry o-rings that came a little out of the groove become smashed and distorted, too much friction to return into the groove when unlubed.
One other trick I've heard a few times is if the o-ring stretched a little, sometimes putting it in the freezer will help tighten it back up.
You can honestly reuse the wheel half nuts indefinitely, the key is try to remove the rust & paint off the studs, then spray it down real well with a good penetrating oil (Kroil, atf-acetone mix etc) or even use some grease on threads! The goal is friction reduction so the threads don’t get hammered.That's what I ended up doing. It worked out well. Then I got greedy and tried to reseal another wheel and the nuts and studs started to strip. They must have been reused more than once . Always something . Thanks for the info.
