tire bolts not coming off
TacticalDoc
26
Otisville MI
I tried with an impact wrench but I dont think the on board tanks supply enough air. Then I tried the chrowbar and still wouldnt come off. I also put on some WD40.
My front driverside tire is flat which is why I'm replacing it with the spare.
Any suggestions?
1,193
I know this sounds silly but, are you reading the directions in the tech manual?
TM9-2320-361-10, chapter 3-14.
There are over 7 pages of info listed to explain how to change your tire. It is very thorough. It was written for people with almost zero experience to achieve such a basic task.
littlebob
27
Baton Rouge LA
Like Evil said make sure your turning them the right way. My truck had hubs swapped side to side, look at the threads or marking on the studs. You also need to make sure you have an impact with enough torque for the job.
3dAngus
102
Perry, Ga.
In other words, on the drivers side, you're tightening them instead of loosening them.
They are reverse threaded on that side.
TacticalDoc
26
Otisville MI
I'm turning them clockwise and jumping on the crowbar
It takes about 1 day for it to deflate so I may just try some fixaflat to see if it seals it up. I need to move it to a friends house.
3dAngus
102
Perry, Ga.
Then pump it full of air, bring immediately to the tire shop, and let them put the big compressor air wrench to it. I had to do that one time on one of my M105s. I've removed 20 tires off it without major issue, but one would just not go until he put the largest wrench and compressor of all on it. Make sure you tell him it is reverse threaded.
Surely you have an emergency glad hand line to go to the back of your truck for filling tires with air.
1,193
Do not assume anything, identify the thread direction visually, then proceed.
There should be a letter "L" on the end of the stud.
TacticalDoc
26
Otisville MI
I do have glad hand line and air hose
I was thinking of keeping the crowbar on and moving forward using the ground and truck weight to losen it. ANyone ever try this?
eagle4g63
35
North/west Indiana
Also if you are talking about an A2 deuce....it has tubes in the tire so.....don't use fixaflat any large truck tire shop will fix it. By me they only charged my $25 to break it down and clean all rust and replace tube......NOT worth my time to do it myself for that price.
TacticalDoc
26
Otisville MI
part of the reason I'm getting out of MVs and selling my deuce is that I dont have mechanics here willing to work on deuces. I'll see if the will change the tire but who knows. You would think its all the same but I guess not here in Central FL.
1,193
You can also call and have it done at your location.
Evil Dr. Porkchop
350
Colchester, VT
It could also be as simple as a valve core, and you could fix it yourself. It would still be a good idea to break all the lugnuts free, and hand tighten them with the wrench incase you need to change one out on the road.
seabeeut
Conn
BAD idea when you apply stress and tourge with out any control there is no telling where that tool might go flying!!!!!!
3dAngus
102
Perry, Ga.
If you got it at the correct angle, you could probably bump it and break it loose. I would not go more than a few inches, and you need a second person to watch it on the ground.
In any case, you motivated me to get out in this cold wind and break a tire off my M1061. With my Gimpy geared lug wrench and a sliding hammer crowbar, they broke loose without to much trouble. They are also reverse threaded on the driver side.
