tire bolts not coming off
3dAngus
101
Perry, Ga.
Are those gears suppossed to mesh where they help each other out. I think I'm doing something wrong with the geared lug wrench. Not sure how to use it. I feel dumb.
jbsapp
NC
Yes, if you are removing or installing a dual, the gears must line up. Assuming wheel removal, it takes a bit of jiggling and rotation to get the inner socket to line up with the inner thimble and the outer socket to line up with the outer lug at the same time. Make sure you are at a near perfect 90 degree angle and it will go in easier. But you'll know when you get it because the big gear will line up perfectly and lock in. Then use the little bar for the outer lugs, then the big bar for the budd thimbles.
Once the lugs are loosened up, you can slide out the big gear a little and line up the holes, then put the little bar through both holes and turn until fully off. This 'deactivates' the torque reduction gear so you can get the big lug off faster.
If the inner is rust welded to the outer lug, then just make sure the inner is somewhat tight with the big bar, then remove the big bar and use the little bar to get the lug unstuck. Amazing.
Just watch out for cases where the bar cannot rotate any more because it's pushed up against the shoulder of the wrench itself. I scratched my head wondering why my lugs were so darn tight when I realized that the wrench couldn't turn at all. Doh!
If removing a single (front), stick the big pipe into it and anchor it towards the ground. It wants to rotate in the opposite direction that you move the little bar. Pop the lugs off with the little bar, which works against the leverage of the big bar (the reaction bar). It's an ingenious tool.
timothy1
in
Impact isn't getting enough air to it. I bet you don't got 1/2". Connector and air hose. Big impacts need air to get proper use out of them.
73m819
327
gainesville, ga.
Just so you know, some lug nuts come off real hard, It took a 10' cheater pipe to get some of mine off, broke two 3/4 extensions, one 3/4 drive, one stud, one bud nut,
TacticalDoc
26
Otisville MI
I put on end of the bar on the curb and jumped on the other end
I bounced up about a foot each time. Im 195lbs...would have been funny it it did loosen
Vintage iron
Falmouth Ma.
I use my Gear reduction to loosen stubborn lug nuts. It works every time! You cab get them though ebay. They even come with the sockets you need.
Vintage iron
Falmouth Ma.
Go to eBay and type it in. It is on YouTube too! No more jumping on the lug wrench, just twist the crank. It is called a gear reduction lug wrench. It braces it's self against the hub. It will break off a wheel stud if you go the wrong way! Best tool I ever bought.
goldwing2000
Banned
506
15
Ingham County, Michigan
its the hose used for filling the tires with a quick connect
Definitely not big enough. Those quick-connects are only 1/4" and you'll be lucky if the hose is 3/8". Get a 1/2" air hose ($20 from Tractor Supply). If you don't have a large air compressor, put a gladhand fitting on one end of the hose and thread the other end directly into your air gun.
TacticalDoc
26
Otisville MI
no results on ebay but did a online search
