BTN
- 0
- 0
- Havelock, NC
Apparently the military didn't use three rails. At least the pub only shows that one p/n for the 9.00x20 and another p/n for the 11.00x20. I may have a couple for the 11.00x20, at least they're bigger than all the others. I will try to measure them tomorrow and see if I can figure out what they are. I don't know if you could make the ones for the 9.00x20 fit with modification?
The description says the chains for 9's are 17.125" wide, so sounds like they may be wide enough, but I would at least use some of those spring chain adjusters if fitting them on the 11's. Some of the commercial chains list same p/n for 9.00x20 and 11.00x20, but they usually have some adjustment. Could possibly add some extra link or adjustment to these chains for 9's and make them work.
