Hoxman
- 0
- 0
- Merritt Island, FL
Hello,
I found my driver's side front tire (super single) flat the other day.
All the rest are ok and I did not start it up and let the CTIS bleed them lower because the idle rpms weren't high enough to put pressure in the system.
I aired it back up and it took 2 days to go down again. We sprayed the entire tire with leak detector (not an easy job on those big bastards.... And the ONLY leak we found was the valve core....
We pulled it out and it was corroded so I replaced it with off the shelf short valve cores from Auto parts store... Fit correctly (I think) and aired it back up... It went flat in less time with the new core in it......
Do they take special valve cores? Is there something else I'm missing? Anyone else had this? (I'm sure someone did)....
Any help will be appreciated!
Thanks!
-Hox
Thanks!
-Hox
