- 10,883
- 826
- 113
- Appomattox, VA
Spent some hours going over my deuce this weekend, making sure fluid levels were topped and that everything is in order for the big trip next week in the East Coast Convoy, and the trip up and back from Aberdeen. During the inspection, I checked tire pressures, all varied between 25psi and 55 psi. However, my right rear inside tire was completely flat, and the tire was off the bead. The lock ring was in place, but not really well. I got the air hose to air it up, but no valve stem was in place for me to air up the tire! Upon closer inspection, and me reaching underneath the tire (off the bead) I found that there was no tube inside! Not sure the story behind this little episode, but I will make sure I replace the tube before the trip. Good thing I caught that...
Also, one thing I found in my truck was a note, made on the very top of the grille, in permanent marker, by a former user of the truck. I could barely make out the letters, so I wiped off some dust and pollen that had settled there and I could make out:
"I WAS 'H' CODED, NOW I'M UNSTOPPABLE"
For the story, my truck had a freshly remanufactured engine put in place 37 miles prior to surplussing it out. I can deduce two explanations for this comment:
1. The truck was formerly listed as "H" code (unserviceable), and got the rebuild treatment at Toole Army Depot, and whoever scribbled that statement was amazed at the newly acquired power the truck has with its new engine, as well as I will be when I get her on the road.
...or....
2. The truck has no brakes. (unstoppable = no brakes?) I hope this isn't the case.
...or....
