Tire mileage
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
It depends on their age and condition. The casing may fly apart in a few hundred miles.
Original new NDTS would be around 20k depending on the load
f3504x4
crescent city ca.
Put new tires on the front steer axles and use the takeoffs as spares.
Get your tools ready. Is this like a 16 day drive?
Not sure how many days. I take it 900x20 tires wont last long? And i do not know 4 digit number on any of the tires. It will be an adventure im sure. Will a bottle jack raise unit enough for tire r&r? Thank you for taking the tome to respond.
Ron
simp5782
9,338
Mason, TN
Thank you for the information. Where can someone purchase new 900x20 ndt tires?
Thank you in advance.
There isn't that is reasonable
If you want to swap tires go to g177s in 1100r20. Will increase your road speed and they wear like iron. Takes alot to wear em down
f3504x4
crescent city ca.
98G
Former SSG
4,246
Very good to know , thank you once again.
My opinion, not that you asked for it- run with what you have . You have plenty of spares. Change out to 395's on mrap rims with spacers at some point in the future.
G177s look good on a deuce. The clearance is just barely not enough and they don't hit all the time, just intermittently. There's a solution that will allow them to be used. I don't remember what it is, probably something like a small spacer.
