cten
- 0
- 0
- Georgetown/MA
Okay, I need some help here.
We installed the new alternator and she is starting up great and charging fine now. The voltmeter on the dash is registering green now.
I am a little concerned about the temp gauge. I have only had her running for a max of about 15-20min and thought I saw the temp gauge move to 120, but I'm not sure.
It is still real cold here in New England and it was around 34 today and I do not have a blanket in front of the radiator. I do not want to blow the engine up as she sounds great and I believe the water pump is working fine as I have no reason to suspect otherwise.
The other thing I started doing was filling up the tires and getting them to presure. Is it necessary to take the tires off the truck to inflate them. Because I inflated them on the truck to 60PSI and that is when I found one bad tube and still have 4 more to fill up. The tire seems to be leaking at the stem.
Where is a good cheap place to find tire tubes and what do they go normally go for. The tire itself is fine from what I can see.
I did check Saturn Surplus webpage, but do not see any tire tubes listed.
What else to I need to check before attempting to put her on the road for use?
I remember Joe Green mentioning something about a light for the rear plate and was also wondering if I need to put a beeper on the rear when backing up?
I went to NAPA today to get wiper blades and all I got was a shoulder shrug. I see those on Saturn.
We just had a winter camp out and built a Monkey bridge that was 90' long and all the scouts keep asking me when the truck is going to be ready. My son and I spent 2 hours on Sunday reinstalling the windows and on Monday we spent another 2 hours today alone installing the alternator and we still need to finish bending the (3)bows and reinstalling the canvas back.
I have a friend that has an M37 and was mentioning changing the oil and filters and he was like it may cause more problem changing them and I would be better off leaving them for now. I'm really questioning this one.
My biggest concern is the vehicle not being safe and someone getting hurt, so If anyone can think of anything I may have overlooked and you think of something I need to be reminded of send me a reply.
Hope this is not too long to read and reply to.
Regards,
Regards,
