Mikei998
- 14
- 8
- Lewiston NY
My tires on my hmmwv are spent and time to be replaced . Can I go bigger with out adding a lift? What’s a good tire to replace them with ? What do you guys recommend ?
You can clear 39s but they will rub some. There are several threads on tire choices. With a 16.5 in wheel your tire sizes and brands are limited. Some folks have opt'd to go to 17s and 20in wheels.My tires on my hmmwv are spent and time to be replaced . Can I go bigger with out adding a lift? What’s a good tire to replace them with ? What do you guys recommend ?
What are those wheels offa ?Dodge wheels fit pretty nice, and come in 17, and 18
THese are 17” wheels off a mid 2000’s 2500/3500. They have a +43mm offset which is nice, and they are 8” wide. There is a website that shows all the specs for dodge wheels of this era so you can verify which ones will fit. Chevy wheels and older ford will fit too, but they don’t have as much offset of width which is important for me, as I was already pulling in the tires more than they’d like.What are those wheels offa ?
I thought modern GM wheels changed the bolt pattern, and wouldn't fit? Will a 2015 2500 gm wheel still work?THese are 17” wheels off a mid 2000’s 2500/3500. They have a +43mm offset which is nice, and they are 8” wide. There is a website that shows all the specs for dodge wheels of this era so you can verify which ones will fit. Chevy wheels and older ford will fit too, but they don’t have as much offset of width which is important for me, as I was already pulling in the tires more than they’d like.
i got 8 of these rims and after easily selling the center caps on eBay for a lot more $ than I expected, I’m down to about 10$/rim for factory aluminum wheels. Can’t complain about that.
also, going from the 12bolt stock wheel tire combo to the 39” bfg with dodge wheels shaved a full 40lbs PER WHEEL! That’s 200lbs of unsprung weight I didn’t need.
Would a 2 inch suspension lift solve the rubbing issue if I use 39‘s ?You can always do a couple inch body lift solve the rubbing issue.
From what I read online a 2" lift should be sufficient to run 40's without rubbing.Would a 2 inch suspension lift solve the rubbing issue if I use 39‘s ?
Looks like yes and no, maybe? Use this cross reference to determine.I thought modern GM wheels changed the bolt pattern, and wouldn't fit? Will a 2015 2500 gm wheel still work?
