- 5,586
- 2,866
- 113
- Metairie/La (N'awlins)
I have a steel mrap rim with dual feed valve stems going to the mounted ctis valve. The valve has a broken fitting and will not hold air.
The stems have a small o-ring on the end, ferrule, and a threaded male nut. The ctis female elbow pipe connects to this and to the valve. I believe this is the same style valve stem on hemett wheels with ctis.
Is there a brass adapter that can convert the valve stem (not a big bore) to a regular valve?
I did not want to break down the tire to change the stems if possible.
I saw a post about tapping the inside and outside of the valve stem to convert to a regular valve but saw nothing else on my limited search skills?
