TM for belt change?
markmontana
Mesquite, NV/Layton, UT
I don't have the TM- sorry. It's pretty straight forward, done it several times with no problems. Just get the old belts off, then slip the new belts over the fan, and roll them unto the pulleys. Sometimes they are tight to get between the blade and the radiator housing, but never had too much trouble doing it, just move them as you turn things. I like to get both belts past the fan before slipping the first belt onto the pulley, makes the fan easier to turn to get the second belt on. (This for the 2 alternator belts- not the compressor belt. Have the wrench, but haven't had to change one yet)
wsucougarx
65
Washington State
You DO NOT have to remove the fan. Loosen the alternator and push it up towards the engine to loosen the alternator belts (2). The air compressor pulley is a two part pulley. You will see there are two bolts on the pulley on the forward most part of the pulley. You will need to loosen or remove them. Now like I said before the pulley is a two part pulley that is threaded. The belt is basically sandwiched in there. You will need to get large wrench to hold the rearmost pulley in place so you can loosen the forward most one. Unless you have the air compressor pulley tool, it'll be a challenge to break it loose. When you get things figured out be sure to put some anti-sieze cpd on those threads for your next belt change.
