TM needed, Futronic 225-01 Automotive Military Low Voltage Circuit Test Set 4910-092-9136
Mogman
10,581
Papalote, TX
I am looking for the TM for the Futronic 225-01 Automotive Military Low Voltage Circuit Test Set 4910-092-9136, I have looked at TMs 9-4910-448-10, 9-4910-489-10 or 9-4910-509-10 and these are not correct for this device.
SCSG-G4
PSVB 3003
5,403
3,508
Lexington, South Carolina
Have not found the TM yet, but I did find some other mfg model numbers LVR-3E, MILT10308
NSN 4910-00-092-9136 Datasheet
Width:
18.000 inches
Length:
15.000 inches
Electrical Power Source Relationship:
Self-contained
Material And Location:
Steel carrying case or aluminum carrying case
Inclosure Feature:
Single item w/carrying case
Test Type For Which Designed:
Measurement of voltage and current in low tension circuits of 6, 12, and 24 volts
Operating Test Capability:
Ammeter range 3 to 0 to 10 amps; range 15 to 0 to 50 amps; range 30 to 0 to 100 amps; range 150 to 0 to 500 amps; voltmeter range 0 to 1 v; range 0TO 10V; range 0 to 20 v; range 0 to 50V
Height:
12.000 inches
NIIN:
000929136
NATO Stock Number:
4910-00-092-9136
Shelf Life: N/A
Repairability:
If condemned or uneconomically repairable , then dispose at direct support (ds) level.
FIIG:
T228-A
Mogman
10,581
Papalote, TX
Evidently the NSN was used on several modestly different model/manufactures with different specs, kinda weird.
The one I have works fine and it is pretty intuitive in operation, I would like to have a correct manual, the one I have only does up to 100A BUT it can sink up to 100A for 10 min on and 10 off, one of the other boxes I saw with the same NSN would do only 50A for 3 min on and 27 min off.
It also can connect to an external shunt like the one on the HMMWV to test cranking amps.
