To Purge or Not to Purge | 855 Cummins
Zoidsfan77
Columbus, Ohio
I should mention also, when getting ready to set the overhead, I attempted to stop the engine using the emergency stop lever. However when pulled, it did nothing. The engine continued to run, unaffected. Same result if I actuated the lever directly on the pump outlet. I am not sure if perhaps it is related to my low power issue.
