nickd
- 57
- 28
- Newport, Delaware
Posted on the G today also....
Today was surely Friday the Thirteenth. On the way to pick up an m1102 trailer at Ft Mead, about 3 miles from the main gate, the engine started to really get loud, oil pressure was normal, it was cold out and the water temp was normal. Having no other choice, I ran it to the base to the Gov. Liq. yard where it finally died. Since there is no hole in the block and no leaking fluids, its a terminal case of internal damage most likely a spun main bearing. The engine locked up 90 miles from home. Luckily I was able to get a flat bed and the folks at GL allowed me to stay warm till the truck arrived.
So, selecting a replacement engine is the question. 6.2 replacement or upgrade to the 6.5 non turbo. I am leaning toward a reasonably priced 6.5 non turbo new in the crate. Will the 6.5 engine drop in and mate up to the existing transmission? If so, I may go that route. If I can find a reasonably priced new transmission with Park I may just change it out as there is a new transfer case already installed. Changing out the transmission now will put a new drive train under my butt.
Any suggestions?
Any suggestions?
