Today was a great day
shannondeese
High Springs Fl
Today my deuce rolled under its own power for the first time in 6 months. After getting the starter rebuilt. Rewiring the charging system. Installing TMAmericas alternator kit. Relocating the primary fuel filter. Installing an SI27 alternator. Replacing all the belts. And installing two new batteries. She fired right up, put out good voltage and runs as strong as ever. Thanks for all the help from all of you.
Dipstick
1,267
Effort PA
Great news Shannon! You put a lot of work into it. I just replaced my batteries and belts too only to have something go wrong and cause a dead short to my new batteries. Looks like I have my work cut out for me. Enjoy your truck!
shannondeese
High Springs Fl
I had a starter hang up like yours. It took out the #2 wire from the alternator to the starter too. I didn't know it at the time though. So after I put the starter back in I had no charge. The truck would crank and run. Just wouldn't put out voltage. It took a few days to figure that one out. I ended up rebuilding the whole charging wiring harness. And it took out the voltage regulator too so the old alternator puts out 36 volts no matter what I wanted it to do. It's done now and I can thankfully drive it again. Good luck with yours. Eventually you'll get it back together. That'll be a great day.
swbradley1
Modertator
1,656
Dayton, OH
Certainly good news. By the time mine is on the road again it will be closer to 16 months.
