Trango
- 23
- 18
- Boulder, CO
Lately, I've been trying to track down the cause of a weaving on highways with semi ruts, which manifests itself as a dead spot in the wheel and a slow, well, weave from the rear tandems.
This task is is tough because I've changed just so much on this truck. I'm singled with dually wheels in back on the outside track, and the front wheels are custom to match the rear track.
Lately, I've shimmed the wear-bushings on the axle brackets that hold the rear leafs, to eliminate some movement... this has seemed to help. The steering linkage was also just a little loose around the ball stud, so I tightened that up as well - next step is to tighten up the steering gearbox itself, even though the steering wheel seems very tight.
Caster measures out to about 5 degrees, so that should be good.
My question to the group is how much caster are people with radials running? I just threw a tape on my front tires, and the measurement between the front faces of the tire was only 1/8" narrower than the rear, which means there was very little toe in.
Thoughts? I cringe to take this thing above 60 on heavily scarred roads.
