m32825
- 115
- 43
- Central Florida
I set out to change filters and fluids this morning and decided to run the unit briefly to make sure everything worked beforehand. It started up and ran just fine, as expected. Then I turned the master switch to off... and it kept running!
After taking this in for a few seconds I hit the emergency stop switch... and it kept running!
I had less than a gallon of fuel in it, so it was just a matter of time before it came to a stop. While it ran on I started investigating and found that the fuel solenoid linkage had become unattached from the lever. I moved the lever to the off position and the unit shut down. Whew!
I had previously noted the linkage was loose and tightened it, this time I used some Loctite on it. Now it starts and shuts off like it's supposed to and I'm hopeful I won't see this problem again!
-- Carl
-- Carl
