took deuce offroad for first time in river
bjsmith
zachary,la
usually ride 4 wheeler down there but decided to try it out. dont have many pics but here are the few i have. only got stuck once luckly 3 jeeps with winches came around the corner soon as i steped out the truck
FMJ
37
Las Cruces, NM
Looks like fun, not much water out here in NM, I'll guarantee you have water/mud in your axles. . .
Make sure you check!
bjsmith
zachary,la
plan on checking axles in the morning only fluid not changed yet looked new when i got it so probly will be changing anyway
Heavysteven
10
Hickory Flat Ga
If you want a wet look you can use tire shine on CARC and it will look like new.
Looks like you had fun to much PCMS for me to take mine in water. Guess I am getting old.
Mike929
22
DFW, Tx
Curious, with all the aftermarket support for the Rockwell axles, are their products out there that will seal up the axle better to make it more tolerant of this type of fun?
... or do the people in the high priced off road vehicles have to do the same maintenance on their beefed up axles?
FMJ
37
Las Cruces, NM
The axles, in stock military trim, aren't very water friendly. Conversion of the rear axles to disc brakes might help, never really looked into it that much because they aren't rated to stop a fully loaded Deuce. The front axles, I've seen after market boots for the front, but being submerged in water for an extended time will usually result in some water intrusion.
rchalmers3
30
Irmo, South Carolina
bjsmith, your playground looks awesome! I like pic #2 where your deuce is churning through the deep water. It reminds me of a river boat scene!
Glad you got a chance to take her out, get her wet and get stuck! that is what fun is.
Rick
593
12
Ville Platte, LA
BJ, what stream is that? Since you're in Zachary, I figure it could be the Amite, or maybe Thompson's Creek? Looks kinda scary, the streams around here, you could drop a tire in a hole and get really stuck.
That CJ looks like it must have Rockwells under it, or certainly something larger than what it came with. Mine is still bone stock.
LC
ETA: That yellow vehicle looks real familiar, there was one just like it for sale 1/2 mile down the road from my home. LSU trim and all.
Mike929
22
DFW, Tx
My brother spends a lot of time with his friends going up and down rivers in his area. I had mentioned that as one of the selling points to me getting a deuce, and I am now cringing a bit. :)
I know there is a procedure you have to do before going through the water and then reverse after you are finished. I also know about the fording kit which I will need to look into, just want to avoid the words "sand" and "gear oil" in the same sentence. :)
EMD567
Driver for the Ga Mafia
47
Aiken SC
Just like a southerner. Carry the 4 wheeler high and dry in the bed of the deuce.
Just wish I was there so I could play with the 814 in the wet........:mrgreen:
bjsmith
zachary,la
i went again today and almost got stuck again but was by a guys house with a dozer then realized i didnt have front axle engaged after that no problem .it is on the comite river most places are not over 3' stay mainly on sand bars till need to cross. the bigger jeep had 2.5 rockwells but the front way making bad popping when he was trying to back out after he got stuck there he had to be winched too. had to take lots of people for a ride today when they seen it:)
bjsmith
zachary,la
the 4 wheeler was there so if something happen i could get home easy or get help and it has a radio so when i stopped i had tunes to play
