tool kit, tool bag
reom35a2fluiter
Netherlands
for my deuce and a half I am looking for tools in the tool bag sits.
the bag and wheel wrench I have at my disposal. but what else has to get stuck in??
I hope you send it with pictures??:cool:
Flyingvan911
158
Kansas City, MO
I don't have pics right now but my deuce's tool bag had a large and small cresent wrench, jerry can spout, flat blade screw driver, square key for the lube plugs, and a couple of things I can't recall at the moment.
Katahdin
23
Scarborough, ME
To change the starter you need a thin walled 15/16 socket and a ratchet swivel. Depending on the starter model, you may still need a stubby or cut down 15/16 open-ended box wrench to rotate the nut closest to the frame. For this job also pack a thin strap to tie around the starter solenoid. It makes it a lot easier if you have a second person raising/lowering the starter with the strap while the other person works the bolts and guides the starter into position.
