Top bolt on Alternator sheared off
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
No. Wolverine technologies makes junk in my opinion. Overpriced and not up to spec. The mount setup probably has a rear drop bracket and it shouldn't be. It should be a short hinge j180 alternator. With the correct spacer bracket with both mounting bolts on the same mount
Get the correct cummins bracket and j180 alternator, run a power wire directly to the starter from the brushless unit and be done.
rccjunk
Tomball, TX
Gotta link to get a better setup?
simp5782
9,260
Mason, TN
Gotta a link to get a better setup?
Replace your upper bracket with the one below. Flip your alternator around and put the two mounting bolts on top.
Uses napa belt 25-080680 which is the stock one.
