top speed
Coug
4,241
Olympia/WA
is it an A2 variant or an ECV truck?
According to the manuals, an A2/M1123 truck (non turbo 6.5 with 2.73 gearing) has a sustained top speed of 78mph.
An ECV/REV truck with turbo 6.5 and 3.08 gearing has a top sustained speed of 70mph.
Early trucks with the 3 speed transmission had a sustained top speed of 55mph.
Notice I'm saying "sustained top speed" and not just "top speed"
The trucks can go faster than those speeds, but it's definitely NOT recommended. Especially the 3 speed trucks; they have heat soak issues with the rear cylinders of the engine, and can destroy the engine if driven too fast/too much load for too long of a time. a 2001 truck SHOULD (no guarantees with these things) have a GEP 6.5 with better metallurgy that is much better, but as I said, no guarantees.
TOBASH
3,364
Brooklyn, NY
So the A2 is faster than the turbo REV truck which has 30 more hp?
Speed and horsepower are apples and oranges. Speed is about distance over time. Horsepower is about Force over time. Horsepower will allow faster acceleration but gearing ultimately decides top end speed.
Mogman
9,146
Papalote, TX
Not at all true,,,,
You can have all the gears you want but if you do not have the horsepower there will be no speed just bog.
Otherwise we could set world speed records with lawn mower engines, it takes horsepower to go fast, that is why as aerodynamic as a Bugatti is it still takes 1000HP to push it to 250MPH, Interestingly only 500HP to push it to 200MPH, they say transitioning from 200 to 250MPH is like transitioning from pushing the vehicle through air to pushing it through water.
TOBASH
3,364
Brooklyn, NY
Change your diff gears to 2.56. I think pulling a thousand pound house in a thousand pound trailer that will act like a sail would make 70MPH unrealistic in a HMMWV with stock tires. Swapping to 40” might help.
TOBASH
3,364
Brooklyn, NY
Not at all true,,,,
Sorry Mog, BUT ultimate speed is limited by ultimate engine RPM and gearing. Yes, you need some horsepower to push, BUT in our vehicles it has to do with gearing not HP.
4,735
AS I said, it is a 2001. So it would have a 6.5 4 speed. I want it to pull a horse trailer and go about 70 mph... How many Humvees had turbo's ?
Can it do 70? Sure. Can it do that towing? It might be able to get UP to that speed towing. But it's not going to be happy doing it. And your wallet isn't going to be happy trying to do it with diesel being $5 a gallon or more. You'd be better served with a civilian truck than what you're trying to do.
Mogman
9,146
Papalote, TX
Swapping to 2.56 gears will make it worse, you can in theory go faster but that Detroit ain't got the guts to pull a horse trailer
Mogman
9,146
Papalote, TX
Its got EVERYTHING to do with power and the Detroit just does not have it.
