torque arm nut
73m819
329
gainesville, ga.
rizzo, murry has them (5.50 a peice) ask for robert, i just bought 12 for the 819. a standard fine thread nut wont fit, its way to thick, the nut takes a 2 1/4 socket or wrench, need both to install a 5t torque rod
rizzo
Port Huron, MI
ok, so that is the only place to get them?
I will have to see if they can ship it so i have it by friday. big mudbog saturday.
rizzo
Port Huron, MI
awesome, thanks for the help. now I know why my buddies 5 ton pit truck had steel rods welded across the ends of the torque arm stud. A bolt coming loose must be a somewhat common thing when they are being worked hard.
rizzo
Port Huron, MI
Re: RE: torque arm nut
anyone ever have a problem with this?
73m819
329
gainesville, ga.
RE: Re: RE: torque arm nut
dont see how the nut can come loose , its pulled down tight and a cotter key, i had to cut mine off, even with heat, the nut wanted to deform before it wanted to break loose (on 30+years makes it hard to get off)
i have welded steel bars across a torque arm stud that had the rubber worn out so that the rod would stay in place till a proper fix could be done. a little slopy but it works., when i first went to work for a dump truck owner in cal. i found about half of his trucks had this TEMP fix, dot did an inspection about 2 weeks later, shut them all down
G744
4,118
Hidden Valley, Az
IMHO, the nut on the drive flanges is the same. Two on every drop-in.
dg
