Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
The thingy on the steering that a tow bar fastens in to is bent on one side. If I heat a straighten it with out braking it, will it be ok or will it likely brake later?
Thanks very much.
It isn't bent a lot,I haven't measured. One side is bent out like maybe someone was using and pin came out leaving all pulling pull on one side. Heck maybe someone put a chain or cable through one side. Anyway just one side is bent and no way holes in both sides will line up for pin to go through.
I have been able to straighten one out by just placing it in a large vice and tightening it down slowly with out any problems. Keep checking to see if the pin goes in smoothly. By the way I was able to do this with out heat if it was off just sightly.
Let me know how it turns out
Bob
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
