Tow Bar Loan
salt6
B'ville, OK
Won a M1009 in Greenbrier, AR 72058
Need to borrow/rent a tow bar to recover a CUCV near Little Rock, AR and return to Tulsa, OK area.
Still need to see if a tow dolly will work.
Thanks,
Steve
1,807
I'd loan you mine but you could build one for the shipping costs one way. Do a little searching for fabricated towbars. Many of the CUCV guys have figured out an easy way to use the $75 walmart towbar on the CUCV.
jimm1009
70
Louisville, KY
I had one made about 13 years ago for $100 by a little welding shop with a SAE certified welder. I think that it is 2 inch, 3/16 wall with a 2 inch civy coupler on it.
Unfortunately, I can't get pictures of it until Saturday as I am off on a 1.5 day recovery trip to retreive two M105 trailers @ Hooks, TX base.
If you want to e-mail me with a reminder request I can in turn e-mail some pictures on Saturday morning and then send them to your e-mail address.
jimm1009
Warthog
230
OKC, OK
Did you win the M1009 with the missing left rear window glass? If so I have some new ones. I have a couple of towbars also in OKC.
Ken_86gt
Williamsburg VA
I used a U-Haul tow dolly, but I would never do that again. The truck (M1009) was too big for the dolly, the front wheels were hanging over the sides of the dolly. I recommend building yourself a tow bar.
salt6
B'ville, OK
Thanks Guys.
Won a M1009 from GSA ir AR. Talked to the one of the guys at the yard and says flatten one of the tires when they moved it lafter the last auction. Also says it was the second time it was put up for auction. So I'm going with a truck and car trailer. Will try and make the recovery monday. Still like to get a towbar.
Steve
PS what can I use for a temp replacement for the flat tire? want to just go to the local salvage so I will have something to roll it on.
Warthog
230
OKC, OK
Thanks Guys.
Any '80s GM 15" 6 lug rim will work.
Let me know if you need a window.
Warthog
