Tow bar towing... what about brakes/lights????
maddawg308
745
Front Royal, VA
When Rob and I bought two deuces from Chambersburg PA back in June, and the EUC was approved, I was able to borrow a towbar and light setup from another Steel Soldier. So, that covers the lights (you can homebuild your own light setup with a 6-conductor cable about 20 feet long, a trailer receptacle, and two composite lights). For the brakes, we didn't hook them up, and it rode just fine. In towns and smaller roads, where we had to make turns and stop at lights, we just gave ourselves a little more room to stop. It stopped just fine.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
It's not hard to hook the brakes together. Where the air line goes into the back of the airpack, take the line off and install a male air nipple(quick connect for air tools). Then off the left rear of the towing deuce's glad hand hook an air line to the air pack of the towed deuce.
When you step on the brakes on the towing truck, air is sent to the towed truck's air pack and applies the brakes.
I use a 50 foot air line, has glad hand adapter on one end and regular connector for air tools. Takes maybe 10 minutes to connect the brakes together.
Dennis
dmetalmiki
2,027
London England
brake couplings
I fitted a service line in the same method but(permenantly affixed) on the front as per M54,and a shut off on the airpack.(where its "Td" in) the emergeancy line if fitted as well (twice air store) good for reserve on hills and (required) check braking!
rizzo
Port Huron, MI
RE: brake couplings
I built a light bar and used LED lights
a friend of mine just used it on a 300+ mile trip to pick up a M543 (white in color) that he bought off e-pay. said it works good.
