Towing a 871/872 behind civi truck
jd 9760
Van Wert, Ohio
Can this be done without trouble. I'm pretty sure they are 12v/24v trailers so I guess fifth wheel hieght is my biggest concern. What do you know about these trailers? Thanks
D
Deleted member 11142
Guest
A civi truck/m915 is the perfect tow vehicle for those trailers.
490
Carrizozo, NM
Yes, the trailers have 12 and 24 volt connections. And the king pin height is level for a standard commercial tractor or a m915 type tractor. When you have a 6x6 tractor with the military fifth wheel thats when the trailers get higher.
