Towing a Deuce with a Deuce
stampy
22
Henderson. NC
Agreed with the above advice. Turns will be the hardest thing you may have to deal with. I have flat towed 3 deuces a lot further than you have to go with no fatalities. We did tie the steering wheel (which makes the towed vehicle want to go straight when you turn). The front tires will chirp a little in turns but as long as you take it easy you should be ok. I am assuming you have a proper pintle type towbar and safety chains.
