towing a m101a1 with civvy truck
BSH
Baraboo, WI
What do you intend to do with your trailer? Will it be a home utility trailer, always pulled behind your civvy truck(s)? Or will you be getting a deuce, CUCV, etc.?
By way of example, I don't anticipate that I'll have a mil truck anytime in the foreseeable future, and I want the trailer for just hauling stuff. I'm going to take the existing wiring harness completely out of my M101 and put a new 12V system in. If I thought I was getting a mil truck, I might do a bulb swap, or rig up new lights to the existing harness.
Mike_Pop
NJ
Stock 12 volt bulbs are #1156 with one filament, #1157 with two filaments. If you keep the 24 volt bulbs, they will be dim.
deucebigalo
South River, NJ
actually i plan on this being solely used right now with my civy truck.....i am replacing the wiring with new wiring for a 12 volt system... i was wondering if it was needed to swapp out the bulbs. i see now that the existing bulbs will not be bright enough. so i have purchased new bulbs #1156 from a local pepboys im picking up the trailer on 2/25/08 from pa and doing the wiring at letterkenny befor i move it out.
isaiah
honolulu.hawaii
Re: RE: towing a m101a1 with civvy truck
I noticed they are very dim while towing with my M1028. So will they will get brighter with the 12 volt bulbs? why is that? :?
