Towing a purchased trailer home?
TSCoating
Raleigh, NC
Do they have any issues with this?
I want to buy a couple of smaller military trailers for my business and want to see if we can take a couple of our trucks up there to pick them and just hook them to the trucks and pull them home.
Probably about an hour drive or so from the GL location to the shop.
swbradley1
Modertator
1,945
Dayton, OH
I've towed 6 home in the last year. Just pop over to a Harbor Freight and get a set of magnetic trailer lights.
Unless you have a tall truck they will not run level though. Just take it easy.
MDSA
13
Valdese, NC
We have brought 5 home. Most trailer lunettes are much higher than a pickup hitch, so you need to plan on carefully lowering the trailer tongue, or backing up onto wood to raise your hitch high enough to connect. Also, plan on low tire pressure, trailer lights are 24 volts so you will need lights as previously mentioned, and tools - no telling what you will need.
TSCoating
Raleigh, NC
Thanks, guys! I plan on getting pintles with a rise on them so they sit more level. I'd be pulling them with a 2000 Z71 Sierra and a 2005 Silverado.
I'll bring a compressor, tools, trailer lights, and some wood, just in case. :grin:
MWMULES
352
DESOTO, KANSAS
Also give the wheels a GOOD rocking just to make sure the wheel bearings are OK. In the last two year I have gotten , one that had no bearings in the hub and one that the lock nut was loose and just happen to see the wheel wobbling about 2 mile outside the gate.
3,203
Bring a 1 1/2 socket for the wheels. One of the trailers I got had loose lug nuts.
SCSG-G4
PSVB 3003
5,403
3,508
Lexington, South Carolina
I pulled a 105 from Montgomery, AL to Columbia, SC (350 miles) with a Ford F-150 without problems. Raised pintle hitch, light set, lug wrench, grease. Be sure to air up the tires, check the lug nuts for tightness, and if you don't inspect the wheel bearings, pull over and check their temprature about every 5-10 miles to start, oh, and make sure to release the hand brake - much better gas mileage that way.:wink:
