Towing with tractors
M1075
Oklahoma City
Standard operating procedure is to use the same size truck (or larger) to tow a disabled vehicle with towbar. Many add additional weight in the cargo bed of the towing truck to keep the tail from wagging the dog. So what about tractors? Are they the least preferred model for towing? Is the wrecker best (heaviest), the cargo good, and the tractor marginal?
oifvet
9
(near) Xenia, Ohio
I think the key to success is to get the front axle of the "towed" vehicle off the ground. The wrecker does this. Otherwise, it's just a pintle tow which I don't think was ever designed to be a long-distance tow. There is a SS member I've seen either in the photo section, or as his avatar, that piggy-backs a deuce on his tractor, which I've always been impressed with.
jasonjc
291
Gravette Ar.
The military uses a 5th wheel lift thing for towing with tractors. That is the perferred way for M915's and bigger.
M1075
Oklahoma City
A lift tow is good because you get some downward force on the towing vehicle and the towed vehicle will track like a trailer. It does require a little more prep work, but I would agree it is a better method. My original questions were in regard to flat towing with towbar.
oifvet
9
(near) Xenia, Ohio
In that case, I would say the tractor would give you the advantage of simply having a better view to the rear. You won't have to rely on mirrors only as with the cargo, trying to see around that big box. Tractors don't like bob-tailing. The ass-end bounces too much which is obviously a safety issue if you're towing. "Flat-towing" is a short distance option.
Your speeds won't be that great, so it should be a fairly safe operation on improved roads and highways.
2cents disclaimer.
1,824
Well, my little tractor is just that, little! I've used the towbar on many an occasion and it works just fine but let me tel you, the piggyback device works awesome. You can back it anywhere and the tractor rides like a dream with the est 7000# on the back. The major drawback is loading and unloading. Twice I've unloaded without major equipment. Once backed the truck off on blocks and once used heavy ramps on the back tires of the tractor. Since the tractor is sold now, the piggy back device has taken residence on the top of the shopvan body probably never to move again.
jwaller
19
Columbia, SC
I just flat towed a 816 with my 818 and it worked just fine. common sense required but it wasnt bad at all. I was prepared for some fireworks.
jwaller
19
Columbia, SC
Re: RE: Towing with tractors
wanna sell it? pm me with details if you do.
halftrack
13
New Orleans, LA
I like using the M818 for towing for the same reason stated earlier that you have more visibility when towing the load. That being said, for long tows, I use the M816 with the front wheels of the towed truck off the ground. Just remember with the tractor you got that truck towing and being towed weight difference thing going on.
