Township Fire Truck
AMTAK
Elizabeth PA
OK think I found the wiring problem :shock:
I started on the brakes. Took right front drum off checked wheel cyl and it was bad, changed it no problem. Then I went to change the seal and it is bigger than the new one and is two piece. The new one wont fit. Whats up with that??
I don't think the radios are the wiring problem. What do you guys think?
jasonjc
290
Gravette Ar.
I think the BLUE engine is the problem :p
I've seen the wiring problem before many many times before. I have night mare about those wireing jobs.
What happen is "fred" put the light on, then "bob" put in the new(e-bay)siren , then "joe"added some spot lights he "found".
Then "billy" who is the elec eng at the "plant" and who knows more than fred,bob,joe and billy put together "fixed" it all. With "stuff" from the "plant" because the outfit that does this stuff whants way to much $$$$ just for some wire on a truck. Then "stan" came along and had to fix it again after "mike" rip some wire lose at the "big fire". fat lady sings :popcorn: :deadhorse:
