coachgeo
- 3,404
- 113
- North of Cincy OH
TPMS (Tire Pressure Monitoring System)
experimenting with the one i purchased while back. Just getting around to putting it on. Have it sorta installed. One thing it can monitor with its *external sensor(s) is temperature of tire... You can set it to warn you when it gets to a high "x degree f" and a low temp too. Any guess what temp should set these too?
*external sensors
> sensor is put on valve stem and way it fits sure to be damaged off road... But you can unscrew and stow away
> looks like will add two steps w/tool provided (or better "little" 12mm spanner) to air up/down tire via air chuck (my citis not repaired yet)
> sensors auto shut off when sitting to save battery. Start transmit again when your moving.
*external sensors
