- 16,254
- 23,030
- 113
- Burgkunstadt, Germany
Greetings,
I was asked to provide a listing of parts to have on hand for the MEP-802 and 803A gen sets. All parts are the same for the MEP-802A and MEP-803A generators in this case.
The following parts in red are service parts. By TM, figure number, Item number, NSN and Army part number. As of yet, I have no civilian part numbers.
The parts in blue are things I would have on hand, higher failure rate, and cheap.
The primary fuel pump is a show stopper if it goes bad. Was kinda expensive a while back, not sure about now. You can replace it in a pinch with the Aux. Fuel pump if you dont mind bending your steel fuel lines a tad.
The Aux. fuel pump filter needs to be changed only when you use the Auxiliary fuel option often or for long time periods.
There are lots of other parts that I would keep on hand if I had loads of money. Nice to have things and of course the show stoppers. But they are expensive if you buy them from a vender. If you can get a junk generator cheap, good source of extra parts.
TM9-6115-641-24P Generator Set Manual
Figure 16 Item 36 3030-01-375-8087 88-20273 Battery charging Alternator Belts
Figure 17 Item 73 2910-01-378-6025 40193 Primary Fuel pump
Figure 17 Item 80 2940-01-376-5666 85285-F Fuel Filter/water seperator
Figure 17 Item 29 2910-01-366-7293 88-21738 Auxiliary Fuel Pump
Figure 17 Item 21 2940-01-365-6536 88-22755 Auxiliary Fuel Pump Filter
Figure 15 Item 17 2940-00-934-7989 P14-8969 Air Filter (Donaldson)
Figure 8 Item 22 5920-00-539-6920 F03A125V30A 30 Amp Battery Charging Alternator fuse
TM9-2815-252-24P Engine Parts Manual
Figure 7 Item 10 2940-01-361-5161 186-6025 Oil Filter (Fram)
Figure 4 Item 23 2815-01-139-4010 186-6279-04 Fuel Filter Bowl Filter
