ballencd
- 101
- 43
- Columbus, NC
I did the whole 6.0 LQ4 LS, 4L80E, NP-205 swap for just the TR-6060 cost. Highway speeds aren’t a problem with a 4 speed when you ditch the 6.2.From what I have read, the 6L90E has a larger shaft then the 6L80E. The 6L80E has the 32 spline like the NP-208, NP-241 and NP-242 and I am sure you could convert the NP-205 to work also but a bit pricier. A newer, not sure of the years yet, with VSS output might be helpful for the electronic controller...??? Of course with a manual you could jump start the vehicle when the batter was dead and there is no slipping even thought the auto could lock the converter. It's looking close to the same money but I have not gone deep into the pricing yet. I did get a quote for a new TR-6060 and it seems it was in the $8-9K range....ouch. Not remembering if that is with the bell housing/clutch/etc....not the pedals I'm pretty sure.
I get it. My 6.2 blew an oil line hose and the engine locked up which then prompted my swap. However for where I live now (CO) and what I do (driving up into the mountains) with the truck now the 6.2 would be absolutely miserable.I'm thinking I would have bought a gas truck if I wanted gas besides my engine only has 19K miles on it but I hear you. The LS would be quieter for sure.
My turbo 6.2 is fine in Colorado.I get it. My 6.2 blew an oil line hose and the engine locked up which then prompted my swap. However for where I live now (CO) and what I do (driving up into the mountains) with the truck now the 6.2 would be absolutely miserable.
Mike, I missed this on the first pass for some reason. The CUCV's are PASSENGER SIDE drop for the transfer case. I'm still looking for a better highway speed and think something in the .65-.63 range would be best. Are you having any luck with an OD transmission? My wife wants it to be an auto but I am liking the TR-6060 with 5th of 0.80 and 6th of 0.53....but the 1st is only 2.66. Would have to add the extra pedal to swap to manual though. The 4L60 has a 1st of 3.059 and OD of 0.696 but the 6L80 has 1st of 4.07 and second OD or 0.667 which would be very nice if the controller can be worked out. I have not found a stand alone controller for the 6L80 yet.I have been researching 6L80E swaps as well and I think the biggest problem I run into is, finding a transfer case that is a passenger side drop, that will mate up to the trans. Info has been hit and miss on that. Since GM came out with that trans model, all transfer cases were driver side drop, which won't work for our CUCV's.
I haven't done more research as I am not even close to needing it. Currently I have a Gear Vendors OD with the TH400, so I have something but it's not as deep as I would like. The 6L80E would be a great combo, with the low first gear and deeper overdrive but yeah, not finding a stand alone controller.Mike, I missed this on the first pass for some reason. The CUCV's are PASSENGER SIDE drop for the transfer case. I'm still looking for a better highway speed and think something in the .65-.63 range would be best. Are you having any luck with an OD transmission? My wife wants it to be an auto but I am liking the TR-6060 with 5th of 0.80 and 6th of 0.53....but the 1st is only 2.66. Would have to add the extra pedal to swap to manual though. The 4L60 has a 1st of 3.059 and OD of 0.696 but the 6L80 has 1st of 4.07 and second OD or 0.667 which would be very nice if the controller can be worked out. I have not found a stand alone controller for the 6L80 yet.
