...Track on a trailer...
L999here
South Bend,IN
Finally got this APC on the trailer (M172A1). First time ever and request that any heavy-haul truckers chime in to give me some pointers on tie-down and positioning. The track (Brit FV432) weighs about 15-tons (30K lbs.) and the trailer is a military M172A1 25-ton low-boy on 10.00x15TR tires (8 of 'em). Used 3/8ths. chain and heavy-duty spring loaded binders front and rear. Intend to use more chain and binders on the sides for trips. This configuration was to just get to the local gas station for a fill up. Hope the pics come out OK. Comments and critque are welcome....
Stalwart
33
Redmond, WA
OK, the way you have the chains, if one device or chain fails the vehicle will be unsecured. The tie downs should be independent of each other. I wouldn't drive around the block with the current arrangement. You need 4 legs MINIMUM and since you are running and tightening a single chain at each end it is considered, legally, a single tie-down. 3/8 TRANSPORT chain, (are you using that?) has a WLL of 6600, you need 4 legs of 7500#.
M1075
Oklahoma City
Good point on the chains Stuart. They might be 43 and even 70 would be insufficient with only 4 of them (in 3/8" anyway).
Karl kostman
858
Fargo ND
In ND where I live the rules are 1 chaine per tie down point AND the chains themselves MUST be transport Grade chains, meaning they are each serial numbered and have a tag on them indicating last inspection date, Pain in the butt YES but if stopped that would be a NO GO in ND!
fstfrdy
crosby,nd
in az anything over 10,000lbs has to have a min. of 4 tiedowns pulling in opposite directions(straight from dot.was stopped at two in the morning for an inspection and was promptly told my load was not properly secured). crossed is best. something that sized i would do 6 at least
SETOYOTA
427
georgia
You need four tie-downs points min with 4 binders . X crossed front and rear. I would not take that down my drive way.
srodocker
68
Lacey, Washington
well first thing you should get a m915 or m916 to pull that. or even a m818 :)
nice tank...
also maybe invest in a deuce tanker to follow that thing around to fill it hahaha
oh yea nice trailer + tank :)
deuceman51
9
Scotland South Dakota
Karl,
LOL, I don't even have everything up on SS because my signature is getting too long. I'm at about 34 vehicles now. Somedays I wonder myself when it will end. Dragonman, I will get you all the specs on the chains when I get home in a week.
