Tractor with a bed?
DavidWymore
164
El Centro, CA
How about instead of taking one axle off a deuce you started with a tractor and put a stubby bed on it. Then you'd be shorter and still have 6 wheel drive. has it been done?
vtdeucedriver
Vermont
Someone on here has done that and its SWEET!!! I am a purist and hate seeing chopped deuces but dam that looks sharp. If I came across another M52, I would consider it.
wtrout
Wellington / Ohio
Mine is a tractor that has a 10 foot bed on the back; I think it is a pipe line bed.
It was done that way when I got it. Over all it is only about 8" different the a standard duce.
276
22
Hobart, WA
Someone (local fire dept) did that to the wrecker bed that was on my M543 - they cut off the rear winch and put on a 5th wheel pad - modded the rear wheel covers and then built mounts for the crane to be stowed forward... needless to say I am replacing it with a standard bed - mostly for the 45K winch that was removed!
Matt
