trailer brake controller
rosco
Delta Junction, Alaska
Brake controller
DSCN0012.jpgYes .... one of the earlier Tekonsha (4 or 5 years old) controllers. I just tapped 12 volts from the lower battery. I don't make it a habit of using a lot of power that way, but thought its so seldom used, that I could get by that way... and it works fine. The trailer lights are LED, so they don't care about standard 24V.
dilligaf13
33
south, florida
That's exactly what I'm looking to do. What did you do to receive a 12V electrical signal, to the brake controller, for when the brakes are activated? I was looking to tap into the 24V coming from the brake pedal and stepping it down to 12V.
Did you use the 12V/24V LEDs or just go with the less expensive 12V LEDs for your trailer lights? Thanks.
162tcat
45
Washington
On one truck I have a 24v to 12v converter. On another I run a separate 12v system (additional alt and battery) and use relays to convert signals from 24v to 12v.
