Trailer frame repair / pulling???
oddave715
Lexington, North Carolina
So I picked up a nice "looking" M101A3 from LeJuene. Darn thing has had a forklift ram into the frame right at the rear spring hanger and has bent the frame over an 1" or 2". It pushed the other side frame rail over a little as well. My first attempt to fix was chain it to a tree an hook my winch to the most damaged area and attempt to pull. Well that was unsuccessful. Winch drug my Cherokee. I don't think a ports power is gonna work due to both rails being bent. I am thinking thatif I am going to resurrect this frame Ithat I may have to take it to have the frame pulled. Any advice on getting the frame pulled? Expected cost to have that done?
David
1,178
I had one that had frame damage.
The frame was very brittle and tore/craacked/broke, when pulled.
I would replace it.
With no box attached, the frame is very "movable".
Jeepsinker
456
Dry Creek, Louisiana
Chain it to a tree about 1' from the bend on either side, then hook the pull chain right at the bend and pull with a larger vehicle like a deuce if you have one available.
1,178
Mine was very bad.
I attempted to simply make it movable in the yard for storage.
Every single weld tore on mine.
wdbtchr
St. Louis, MO
I've straightened several bent frames and my favorite tool is two trees. I've used two chainblocks pulling from opposite directions to do amazing things even correcting out of square bends with a 10 ton porta-power from Harbor Freight. But then I have a lot of big oak trees in my neck of the woods. I also have a BFH(big freaking 12# hammer) for fine tuning.
oddave715
I am going to try to hook to it with my 3/4 ton suburban today and see if that works. It's already chained to a tree. And the sledgehammer may get brought out if needed. Torch will definitely be needed for final adjustments at a minimum. Where the fork hit it there is a significant dent that pulling is not going to remove all of.
oddave715
Hooked the suburban to it yesterday. So far it's starting to come out. I need to pull the chains off so I can run my string down the side and see where I am at. I may need to move my chains in a little closer to the major part of the bend. As you get away from that part the bend was more gradual. Once I evaluate where it's at I will pull again. I took some real hard jerks to get it where it's at. So far no welds tearing like Dogheads trailer did. I am thinking that I may weld some braces inside the frame at the rear spring mounts as that is where must of the bend is and the metal is stretched and fatigued there.
DrillerSurplus
Salt Lake City. UT
It is generally not a good idea to weld on frames- welding can create a stress point that causes it to crack. Haven't seen any photos, but are you sure frame even needs reinforcement? If it does, bolting something in would be better.
oddave715
The frames are welded together. Are these frames heat treated?? It is just a small simple trailer if you think about it. Most commercial trailers are much bigger & longer and are just mild steal welded up with no heat treatment.
I haven't decided for sure if I will do any bracing. Gonna wait until I get the rest of the damage repair work done and then decide. It's coming out really well. It has taken some pretty good jerks though. Broke two straps. I am using them to prevent tree damage and prevent damage to the shackle tie down bracket. I'll try to get some pics of the setup today. I was really unsure of how to do this and watched a lot of frame pulling videos on YouTube and looked at tons of pics. So far I am very pleased with the results.
