Trailer Idea
mikew
edmond, ok
Unforgiven,
No, the trailer axles aren't going to be easy to use. The axle attachment plates use bolts to hold the axles and the trailer axles are just to big for the bolts to clear. Jesusgatos is correct, a set of deuce axles with the axle shafts removed and third members pulled is the easiest and most likely best way, but anything 3.5" or less could be made to work.
I've never measured or calculated the tongue weight. It's too heavy to pickup by yourself but it is easy to crank up on the landing gear.
The bed is mounted with 60% of the bed in front of the centerline of the bogie and 40% behind. The front of the bed is located at the same place on the frame tongue as the M105 bed was. The rear of the frame is flush with the rear of the bed. The two frames are joined together, with the splice at the centerline of the bogie.
Flipping the lunette ring just makes it ride level, I don't think the tongue weight changes any significant amount.
mikew
edmond, ok
Or just leave the deuce axles and add driveshafts...
Jesusgatos,
You might be on to something!
If only we could mount a deuce bed on a deuce bogie, extend the frame far enough forward so that there is room for a steering axle, motor and someplace to sit... then we could have the greatest "self propelled trailer" in the world!
mikew
edmond, ok
Jesusgatos,
I think you're correct, you could weld them onto the axle tube. I had not considered that because I'm not a certified welder and I'd never trust my own welds in something critical like that!
