Tranny ?? from a rookie
deuce_m35a2
Levittown, PA
I Recently purchased a m35a2 w/ a bad tranny, The seller gave me a replacement and claims it is good. My question is, Should i be able to shift through gears while trans is on my floor?
I spin the shaft and everthing spins ok, but i am unable to put it in any gear.
I was thinking that maybe i wont be able to since its not spinning fast enough.
I'd like to find out before i install it and find out the hard way when i have to replace it again.
Thanks for your help.
Christian
red devils dude
Ft Campbell
should go in as long as the gears line up but if you spin it and it still wont go then it sounds like a problem I assume you have used older tranny's before and know what it feels like when they go in.
devilman96
17
Boca Raton, FL
Even if it went through all of the gears I would give it the once over... Pull the plugs... look for metal... pull the covers and poke around... give it a good flushing and see what is going on in there.
hndrsonj
Senior Chief/Moderator
361
Cheyenne, WY
Buy a gasket kit and do it yourself. They are very easy just download the manual. I have seen where the pins in the top cover get a little rust and it will not shift gears even with the top cover off.
