Tranny leak after emergency stop
Abbylind
14
Palm Harbor FL & NM
My M1008 had been running great. The other night I was forced to lock up the brakes when a semi turned in my path. Everything seemed fine but a day later I noticed an "oily" spray on the tailgate. A day later the truck started shifting strange and wouldnt move forward after stopping until I revved the engine. Limped it home and noticed it was leaking ATF around the rear of the tranny and transfer case. Would a quick stop (no impact) cause the seal between the transfer case and the tranny to break loose? Maybe cracked the adaptor for the transfer case?
TIA
Chaski
56
Burney/CA
Clean the daylights out of it and go crack hunting. Transfer case adaptors and transmission cases are known to crack.
Abbylind
14
Palm Harbor FL & NM
I came home and took a gander at the tranny. It appears the leak is coming from the rubber hose connecting line that goes from the transmission to the coolant lines. imagine it would wear out after 33 years!
Anyone know what type of rubber hose to use? Fuel line ok?
TIA
ehuppert
138
Upstate NY
Do NOT use fuel line... Gates makes transmission rubber hose, 27058 for the 5/16. We usaully get it in the 3 foot blister pack. Rated for temp and pressure. Fuel line will work for a while, then it won't!
I'm in the middle of running new steel lines, but not sure if the factory cucv stuff is 3*8 or 5*16. Fittings on the trans take 5*16 tube fittings
edit/add
With that said, Truck should have steel lines from transmission to radiator....
MarcusOReallyus
816
Virginia
That's not original, but it's not a problem. Transmission rated hose will last a long time. Do yourself a favor and get new clamps while you're at it.
Abbylind
14
Palm Harbor FL & NM
I figured out why the lines are terminated in rubber hoses. Years ago the transmission housing cracked due to a bent drive shaft. The repair shop couldnt find the same type th400 housing so the cooler lines were modified to fit the new housing
Abbylind
14
Palm Harbor FL & NM
The plot thickens! The snow melted enough and I threw a tarp under the truck and crawled underneath. What I thought were rubber lines were in fact the metal cooling lines covered in grease and mud! I wiped them clean and lo and behold one of the lines had rubbed through where the cooling line clamp attaches to the rear of the oil pan. I dont know if the clamp was rubber lined but mine was metal on metal and wore two grooves in the line. The clamp had also worn through.
So Ill order 2 new lines and a rubber lined clamp....
cucvrus
10,431
Jonestown Pennsylvania
You can piece the line with a double flair fitting. Even a compression fitting will work. That is your call. Then just split some 3/8" fuel line and add it to the outside. that will cushion the clamp and protect the line. Bending mew lines isn't all that bad. Getting them back where they belong is the best way to get it done. I like the steel lines. Good Luck. I think you have it under control.
cucvrus
10,431
My guess would be 5/16" due to the fact that a 1/2" crows foot wrench will loosen and tighten the fittings in the transmission case and radiator cooler. 3/8" is 9/16". That is an easy fix. 1/2 hour and report back. Thank you. Good Luck.
