Tranny leak after emergency stop
cucvrus
10,501
Jonestown Pennsylvania
I went to the hydraulic shop today and ordered a set of 3/8" hydraulic lines with the double flares at each end. The transmission end has a 90* hard elbow and the top end has a straight end. I can run these up above the transmission and parallel to the engine oil cooler lines. I think this will be a good choice over the stock metal lines on the plow truck. I was at the parts store and they did not have copper/nickel line in 5/16". Not saying they don't make it but the clock is ticking and I need to get this job completed. I still have to remove the oil pan and correct a leak. It may just be the oil pan gasket but the oil pan has a few areas that are rusty and I want to investigate further with the pan on my work bench. I mean no big deal removing the oil pan with the starter and transmission lines out of the way. Have a Great Day. Stay COOL and Be Safe. I will report back on my Mr Rusty thread.
Abbylind
15
Palm Harbor FL & NM
Dr CUCVRUS Sorry I havent been a good test pilot for you. Ive got work starting on Monday. Im going to try to install the lines this week.
I hope the hydraulic lines work for you sir.
