67X
- 2
- 0
- Lonsdale, MN
I changed my t-case oil yesterday. drained about 5 qts out looked really thin..and blackish. Drain plug had a small amount of very fine metal. Put new stuff in went for drive.
I went 15 miles and glanced underneath everyrthing looked fine. Drove back home another 15 miles, went to bleed air tanks and noticed oil everywhere on inside of tires and differential.
T-case was fairly warm but not hot to touch. Checked fluid level the next day and was at 1/2" below fill hole. checked seals..no leaks..plugs not leaking. Oil seems to have been comming from the top of the case at the vent reached up and spun it a bit and it gave me a small hiss. Cleaned everything off and went for a 3 mile drive and no leaks.
I read a tread where someone described a similar problem but sait it was speedo cable. Maybe I somehow overfilled it? Any ideas why it would have done this? Thanks
-Adam
-Adam
