Transfer Case Dimensions 2.5 & 5 Ton
Joaquin Suave
32
Alta & Baja California
Hey Guys,
I've have attempted to search down some rough transfer case dimensions for both deuce and 5 ton's and have had no luck. Would one of you military truck "whizend onces" please share with me where i can find info like drop, offset, and rough dimensions of the range of t-cases.
I am in preliminary stages of planning to rip the POS prototype MD3070 out and replacing the drive line with a MT654 (with MT653 first gear) and a 2 speed transfer case.
Thanks in advance
J.S.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Well, they have the same frame width(34 inches I think) so the width is the same. I'm not sure if the frames are the same height, but the cabs are the same, So I doubt one is higher than the other. Now you just need someone to post up the rest of the info.
I'm not sure exactly what your looking to do, but the 939 series T-case has an O/D high range VS the others 1:1 high range. If your looking for more speed, go with a 939 series T-case.
Joaquin Suave
32
Thanks Gringeltaube!
Besides the info... I love your drawing style.
So i can presume that there is no output shaft offset (left or right) then? The dropbox component of the MD3070 has a 16" drop and a 9" offset to the left. I'd like to stick to Rockwell military t-cases, however i have not found anything that even comes close to that parameter.
All valid suggestions will be greatly appreciated!
gimpyrobb
27,785
749
Cincy Ohio
Yes, the output for the front is offset by 11 inches as shown in the drawing. The way it hangs down, its not too bad off from center. The deuce's front axle's input is just off from center, so the DS angle isn't too bad.
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
So i can presume that there is no output shaft offset (left or right) then? The dropbox component of the MD3070 has a 16" drop and a 9" offset to the left. I'd like to stick to Rockwell military t-cases, however i have not found anything that even comes close to that parameter. ..........
Thanks Joaquín. See additional drawing; I think that answers your question. Obviously front- and rear output shafts are on the same axis.
G.
Joaquin Suave
32
You probably don't want to hear it, but have you looked at Atlas transfer cases?
WOW! I wana try some of whatever you are smoking!
I would suggest fabco over atlas. They are designed for larger trucks.
The bad news is they are rather expensive......used.
Funny you should mention that... I have this Fabco TC-38 that I originally bought to fit into Casa Azul, then opted not to. I have to do some "sussing" to see if i can make it work.
BTW: The scrambler in the backround has an Atlas in it.
Jeepsinker
402
Dry Creek, Louisiana
It was only a suggestion as to contact them and see if they offer or could build something to suit your needs. They do build some transfer cases that can take a lot of input power, shock loading, and just abuse in general. I don't know their product lineup, I just thought it might be worth a phone call.
welldigger
15
Benton LA
Is that tc38 too big? Outputs in the wrong place?
I'd rather have that transfer case over the deuce transfer case any day. Assuming it fits in the space your wanting to shove it in.
Joaquin Suave
32
Yup! I tried to call Fabco several times today but could not get through. The bay area is getting hammered by a HUGE-arse storm. After looking at the case, my guess is that the offset can be swapped. We'll see.
The cool thing is that I am in no hurry. I've let Libelula just sit for a few years and am now I'm fired up to bring her back to life "in a big way"!
