- 3,871
- 497
- 83
- Gray Court SC
Question is there a way for this valve to be pressuring the transfer case.
1984 M923A0
1984 M923A0
Sorry bud but the spring inside of the interlock keeps it unlocked, that is why if you have a hard shifting TC we say to bleed the air off and the spring will unlock it.If you're talking about the transfer case interlock air solenoid, it can and does pressurize the transfer case when the seal stops sealing. I disconnected the air feed to mine and capped both the solenoid and the air line. The spring inside does a good enough job on its own to keep the lever from moving when it shouldn't.
Hmm my memory failed to serve me well. In any case, the lever still stays if you don't step on it.Sorry bud but the spring inside of the interlock keeps it unlocked, that is why if you have a hard shifting TC we say to bleed the air off and the spring will unlock it.
