transfer case issues?? 208 or 241
hokie8358
backwoods ,virginia
:cookoo:i have a np241 from a burb 90 model that was matted to a 400. my np208 messed up in my m1028. i know its for the computer model,speed sensor set up. can you format it to work in a none computer driven tranny? looking for a quick fiX to get me back on the road?or do you have to suck it up and find another 208? ok give me some insight guys
Iceman3005
96
Holt, MI
Just went out and looked at the wife's 89 K-5 civi blazer, it has the NP241 with the cable style speedo. Should be able to find one with the cable style at a junkyard and switch the parts over. Might have to use the tail housing also but not sure.
Iceman3005
96
Holt, MI
No 1 ton pickups, K-5 blazers, and suburbans were passenger side drop until 1991. then body styles changed and transfers cases in these became drivers side drop.
Cucvnut
56
Carver, Oregon
you sure its a vss hook up on the speedo? i have a 241 in my M1008 it bolted right up. i was told 89/90 3/4 ton burb 241c's are the same.
hokie8358
backwoods ,virginia
ya mine has the wiring harness plug in on the tail shaft. no speedo hook up on tail shaft. so i will have to swap out tail shafts? will it have to be from an older np thats matted to a 400 tranny?
4,637
Swap out the sender for a gear drive and remove the tone ring from the shaft and place a ring gear on it.
hokie8358
backwoods ,virginia
if i swap out the gear drive and remove the tone ring from the shaft and plac e a ring gear on it, does it have to be from same model t case or for instance a used 208 from a 700r4 or an older 241? i have sum stuff laying around
86m1028
Murphy TEXAS
I've got the cable speedo style.
I'll swap you parts.
Pm if your interested.
