Transfer case leak findings
ratat98
Shattuck, Oklahoma
I got home today and noticed something shiny under the truck, so I found the transfer case was leaking. Like a good boy, I got on SS and found that a plugged vent most likely is the cause...so I went to take the vent off, and couldnt get it to turn, so I just decided to take the whole panel off that the vent is attached to....
Whoever last rebuilt the transfer case, put a solid piece of gasket maker completely over the hole on top of the transfer case, not allowing it to vent at all. I thought maybe it was supposed to be that way, but after looking at the TM, it doesn't look like it... anyone else have this happen???
ratat98
Shattuck, Oklahoma
Haha thanks! Upon digging deeper, it turns out that the gasket did have a small hole in it for ventilation, however the hole was plugged with greasy goo...
runk
65
Houston, TX
Cleaned out all my axle vents and 2 of the 3 had solid gaskets (home [solider B?] made looking) under the plate. The third one was plugged with the greasy goo...
