Transfer case mount problem
tco3129
Flat Top W.V.
May be in wrong forum. Please advise if so. Both my deuces have broken studs on right side of xfer case. Is this common ? I had to jackleg drill and tap on my 67 with xfer still on truck. Not fun but I don't have a xmission jack and can't afford a new one big enough to handle it. Today the studs on my 70 KJ failed and had to do another jackleg fix. I chained it in place hopefully temporarily. Again , is this common?
John S-B
924
Ostrander, Ohio
If need to drop the TC out maybe this will work, it's how I dropped the hyd. pump out of my tractor. If you can find some heavy angle (you'll need 2 pieces) that will fit across the frame above the TC, you can drill holes in it on either side for some 3/8" threaded rod. Use a bar or some pipe (2 pieces again)underneath the TC with holes for the rod to go through. put a washer and nut on each rod and snug it up enough to take the weight as you unbolt it. Then just take turns lowering each nut a couple of turns. It's slow, but it's cheap. You may also need a couple of small ratchet straps to wrap around the lower bars to keep them from spreading. It's been awhile since I've crawled under the deuce so I don't know how much room for there is for this set up. Hope this helps.
WillWagner
2,408
Monrovia, Ca.
Roll down the windows, put a piece of channel across the doors, remove the pas seat and doghouse. Disconnect all the shafts and linkages, hook a come along or chain fall to the channel and lower the t-case down onto a $5.00 HF furniture dolly. You'll need to drop the spare down to get it out from under the truck. The dolly lets the case sit straight up and down. I posted pics here and I think I still have them on the P/C, lemme look....
