Transfer case output seal replacemtn
sjohn116
Baltimore, Maryland
Has Anyone replaced the seal on the transfer case output shaft? Looks like mine is leaking in the front, and likely not going to be addressed until I can find high speed pumpkins and make the switch (I just reinstalled the driveshafts and the leak looks slow).
scottmandu
36
Texas
Good luck with locating the 3.07 chunks.. I suspect we have seen the last of them.. Meritor does still offer the ring and pinion at approx 2g a set.
sjohn116
Baltimore, Maryland
I imagine some will surface again; it's just a matter of being patient. Steve6x6x6 has been buying these axles for over a decade, I can't imagine he is going to close up shop because his source is forever depleted. But then again, I could be wrong.
scottmandu
36
Texas
All the suppliers are out and it doesn't look good for the next few months. Caimans are being cut up and there wasn't many of them made to begin with.
